Note that some foil shield with drain wire constructions can cause a disturbing amount of common mode to differential mode conversion simply because of the geometry.
Also, usually the pig tail you wind up with in that sort of cable winds up acting as a way to radiate all sorts of hash inside your can (or to pick it up), braided screen cables with a 360 degree termination of the braid are generally far superior (But a pain in the arse to terminate).
What the hell are you doing that a fucking power supply needs this sort of tweakery? I can generally get a pass with just a filtered IEC, and some modest filtering on all the signal lines to take the edge off the edge rate so to speak, my biggest pain point is generally HDMI IO and the 850mumble MHz clock harmonic), but there are ways to skin that.
