Why is it annoying to mount the board? Any pictures of the board mounted. Does the board require holes?
Its visible on their product pictures. Due to the way its designed you need to (un)tighten four relatively long bolts.
Once tightened you are constrained to a relatively small area of movement, so you need to make your sure your stencil openings already line up with the PCB quite well. If its off too much, the X/Y adjustment will not be enough to make sure they line up.
With the common 'put four PCBs around it and fix your stencil using tape' method, you have support on all sides of the PCB.
With the neoden, once your squegee applies pressure outside the PCB contour, the part on the PCB might lift and cause smearing.
Not saying its a bad product, I would buy it again for the volume im doing, but it has some downsides.
With some effort and a 3D printer the mounting can maybe be done better, so with support on all sides and faster (un)loading speed.
Have not taken the time to look into this DIY option yet.
