I had a Philips/Yamaha machine with 8 and 12 mm mechanical feeders and 16+ were pneumatic. But, same issue, the trick is to put all 8 mm feeders together, and then 12 and 16 mm grouped together in every other slot, then the 24+ feeders took up 3 or more slots. If you interspersed 8 and 12 mm feeders then you always lost a slot between them.
Jon
