Obviously the machine is not lifting the part high enough when moving XY axes. Looking at the video, it may be that it has lifted the part as high as it possibly can. Check the machine specs for maximum component height. If it is capable of taller components, then there must be a setting for each component that will tell it it has to lift THIS specific part higher than the default.
Jon
