Hi, I have two HWGC HW-T4-50F and the hardware seems to be quite robust except some details like 32A RCD with internal 0.75mm2 wires
After assembling some simple test boards with about 300 components with each machine, I have been quite happy. Only issue has been that for some reason illumination has been incorrect on one machine and speed has been set wrong on the other. So it has been good idea to buy two and compare. I have been quite happy with these inexpensiv machines.
Two weeks ago, I started to assemble more complex prototypes with about 1200 parts per side. I quickly run into some problems with offset of the parts due to larger board size. I quickly checked coordinate transformation in octave and it seems correct to me. So I think the problem is mostly due to the fact that I made multiple segment of different pcb in one panel and that the pcb itself has some V-carvings on it. That highly increases tolerances.
As some dialog are in chinese I thought maybe it would be a good idea to update the machine and test newer software. Unfortunately I updated the machine to version 8.8.7 T84 and I could not assign feeders anymore and it also had problems with image recognition of a new defined part.
I contacted support and to my surprise sales took some time to support me. Support is difficult over teamviewer as the software seem to hand up when connecting teams or anydesk. It also seems like the manufacturer does not recommend to use footprint library anymore, which I did not understand. I do not want to configure each part by hand on every pcb. So I will go back to older software and check.
I also have read that license is limited to 1'000'000 parts assembling, not sure if that is true. Did anybody hit that limit yet?
Thus, today I will try to downgrade again to T39, T46 or T48 and check. Hopefully one will work. Is there any version you can recommend that is stable and major enough?
Is there anybody who has been working with openpnp 2.0? I have now ordered one machine with electrical feed mods at
https://www.afarco.vn/ for testing openpnp 2.0.
How is the software compared to chinese software? Is there any chance to get the HWGC machine running with openpnp 2.0? Manufacturer does not seem to be interested in it. Is anybody willing to make that journey to openpnp 2.0 with me?
Best Dani
