Hello mates,
I'm very used to apply 24V PLC systems, Allen Bradley
, Siemens, Wago and Mitsubishi but always at 24V. This diesel fire pump is 12V and I was trying to avoid the use of a 12V to 24V boost.
The requirements would be:
Nominal working voltage from 6V (bad batteries during crank) up to 16V (bad alternator), digital inputs, relay outputs and analog inputs 0-10V/4-20mA.
I'm not inclined to use these Logo or similar series, to resource limited.
If not, would you recommend a good 12V to 24V boost ups? From tier one brands, Siemens..Wago Weidmuller.. etc
I can not use any custom boards or special stuff, has to be industrial equipment, this is the project drive 10 year + of parts available
