Author Topic: Video guide for LKPF PROTOMAT C30 PCB milling machine  (Read 5636 times)
Online FaringdonTopic starter
« on: July 26, 2023, 07:01:11 pm »
Does anyone have an English guide video for use of the above milling machine to  make PCBs with?...to use the software with the milling machine?
ie, to mill out a single sided PCB from a single sided  copper cladded board.
« Last Edit: July 26, 2023, 07:03:47 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Offline jpanhalt
Re: Video guide for LKPF PROTOMAT C30 PCB milling machine
« Reply #1 on: July 28, 2023, 08:25:05 pm »
1) The copper thickness on a PCB (1 oz) is quite thin.  So, it needs to be very flat or at least its surface needs to mapped.
2) In your other thread, you stated that a 5-day TAT from JLCPBB was too long.  When will your inferior, milled PCB be done?
The following users thanked this post: David Aurora, Faringdon
