Author Topic: air filter for tig welder?  (Read 1431 times)
Offline coppercone2Topic starter
« on: May 30, 2023, 01:45:32 am »
So I gotta say, the whole concept of this welder with the conformal coating and boards exposed to the stream of grinder dust and weld fumes is just bizzare.
I think they are going about this whole thing totally the wrong way. Rather then to seal it (its still a irregular surface area thats a total bastard to clean), I think the solution is to put some kind of dust filter on the thing.
It should auto shut down if you forget the clean the filters.
Any ideas for a low pressure drop inline filter material that can be used for the welder? I imagined a 3d printed frame with the filter pressed into it. Maybe a modified automotive cabin filter or something..
I also thought to get maybe heavier gauge longer cables so the welder can be put far away from the work area. And perhaps to use my stand *modular gas torch holder* to act like a adapter, so I can have a heavy gauge cable leading to the welder, and then terminate it with a few feet of ligher gauge cable so the hand piece is not annoying.
« Last Edit: May 30, 2023, 01:51:49 am by coppercone2 »
