Author Topic: Small size metal/piecework drilling  (Read 2791 times)
Offline abdulbadiiTopic starter
« on: February 26, 2023, 11:16:55 pm »
How do we clamp or hold quite (very) small size dimension of a metal piece to be drilled as correctly and precisely as the large one easily clamped being so sturdy (as only have 4 inch drill vise with wide hollow in center) ?
« Last Edit: February 26, 2023, 11:21:37 pm by abdulbadii »
Offline thm_w
  • Non-expert
Re: Small size metal/piecework drilling
« Reply #1 on: February 27, 2023, 10:46:14 pm »
You get a small vice, and hold it in the larger vice.
If its an oddly shaped part you may need to use various strategies or a specific jig which is designed for that part.
https://www.google.com/search?q=clamping+small+parts+vice
The following users thanked this post: abdulbadii
« Reply #2 on: February 28, 2023, 02:13:49 am »
Highly recommend you have a good watch of some of Stefan's videos https://www.youtube.com/@StefanGotteswinter/videos
Some of his work is sub mm holes in hardened steel with very high degrees of accuracy.
Other than that Collet chucks or custom softjaws (Lathe Chucks or Vise) are used depending on the shape.
There is also some more expensive solutions including speciality jaws, vacuum or magnetic so perhaps look at https://www.miteebite.com/ or https://piersonworkholding.com/
Offline Overspeed
« Reply #3 on: February 28, 2023, 05:48:29 pm »
Hello
depend of the raw material , on metal parts gluing works nice , after drilling , acetone bath to dissolve the glue even some glue are sensitive to hot water , in jewellery they use a special wax
Regards
OS
« Last Edit: February 28, 2023, 06:06:01 pm by Overspeed »
Offline jpanhalt
« Reply #4 on: February 28, 2023, 05:56:59 pm »
@Overspeed
A precursor of hot melt was solid shellac sticks.  Those were used by jewelers since very long ago.  That is what I learned from an uncle in the early 1950's.  Shellac can also be used on a faceplate for lathe work.
The following users thanked this post: Overspeed
Offline Infraviolet
  • Country: aq
« Reply #5 on: March 01, 2023, 06:29:01 pm »
I don't know precisely the application, but IF (and it is a very big IF) the forces involved are not too big you might consider 3d printing a special jig in two halves to hold the small thing you want to drill in to, making a jig in two halves which can be tightened together with some inserted screws and nuts to clamp the metal part.
Offline matskatsaba
  • Country: hu
« Reply #6 on: March 16, 2023, 04:26:46 pm »
As overspeed mentioned, CA glue the part to a larger workpiece and clamp that. Acetone or gas torch to remove.
If not a one-off then it might be worthy to make a specific holder.
Do avoid hotsnot.
