Author Topic: BMS module for supercapacitors?  (Read 688 times)
Online coppercone2
« on: October 18, 2022, 01:38:46 pm »
I Have 3 super capacitors hooked up in such a way that it would be best to put a BMS on it that has terminal blocks inside of a chassis. The capacitors are 3000F and the charge current is not chosen yet.
What is a good BMS to use? It is for spot welding. I want wires that go to the caps, not the PCB that goes between them, if thats possible
Offline bidrohini
  • Country: bd
Re: BMS module for supercapacitors?
« Reply #1 on: January 05, 2023, 10:42:26 am »
You may find this helpful. It's about supercapacitor management system: https://www.sciencedirect.com/science/article/pii/S1364032121011783
