I'm not in Germany but I presume Aldi sell the same drill press globally?
I'm quite happy with my second one. The first one wasn't terribly well made, went back in it's box and was exchanged an hour later with no dramas for one that seems much better made.
I've spent my working life in workshops that have all sorts of nice, expensive, professional tools including drills. My drill press for home lives on the corner of my bench and gets used occasionally, I just can't justify buying a commercial grade tool.
With care its capable of being a precise instrument. It's also quite grunty and capable of drilling quite big holes.
As for speeds mine lives in it's lowest speed setting.
I did graft a work lamp onto it so I can see what I'm doing better. My wife couldn't understand why I went to the effort of wiring it to come on with the drill - looking back I can't either it means I have to do my final alignment with the bit spinning but the better you can see, the more precise you can work. Drill presses don't do precision the operator does, its all up to you to put the bit where you marked.
My shed has a bunch of these mounted near key bits of equipment (drill press, lathe, vice, electronics bench etc)
https://www.ikea.com/au/en/p/tertial-work-lamp-dark-grey-50355442/Look carefully at the chuck, you need to decide if you want keyed or keyless. Also consider what tools you may use to drill with - a lot of drill presses in this size have 13mm or 1/2" chucks but a selling point for the Aldi one was it has a 15mm chuck. Ideally you want a drill press where it's easy to change your chuck - in the case of my Aldi one I have no idea if it's even possible to change and I put a little jewellers chuck in it for little drill bits that that the aldi chuck wont grip
99% of the time I drill holding the work piece with my fingers against a scrap of plywood. I have a vice, and I do use it on occasion, but I don't think I've ever bolted it down, it's mostly used if I'm drilling into the side of something round.
Final note, I've noticed the same thing with reviews from the US they all seem to be sucking up to the advertisers or scared of being sued or something. One gentleman who seems to give fair reviews to tools in the US market is the youtuber ProjectFarm.
https://www.youtube.com/c/ProjectFarm/videos
