Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Mechanical & Automation Engineering
CNC Conversion kit for a milling machine
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: CNC Conversion kit for a milling machine (Read 3985 times)
xzswq21
Frequent Contributor
Country:
on:
October 10, 2021, 05:17:29 pm »
Hello
I'm going to buy a WABECO F1200 milling machine and I want to use a CNC conversion kit for the milling machine, WABECO CNC kit is expensive
4th Axis:
https://www.wabeco-remscheid.de/frasmaschinen/zubehor-frasmaschinen/nc-rundtisch.html
Automatic feeds for X,Y and Z:
https://www.wabeco-remscheid.de/catalog/category/view/s/for-f1200/id/579/?product_list_limit=32
I think I can use such a kit from other companies,
I have noticed there are MACH 3 or MACH 4 CNC software:
https://www.machsupport.com/software/mach4/
plus I found "GECKO G540 4-Axis Digital Step Drive" but it has a 25 pin parallel port:
https://www.geckodrive.com/g540-4-axis-digital-stepper-drive.html
I think for the Stepper motors and motor mounts (Flanges), I can buy four NEMA stepper motors and I can build the motor mounts manually.
But my laptop doesn't have any parallel port!
Could you please recommend me a reliable solution? (I want to produce precision things)
Thanks
Last Edit: October 10, 2021, 05:26:25 pm by xzswq21
Logged
PlainName
Super Contributor
Country:
Re: CNC Conversion kit for a milling machine
Reply #1 on:
October 10, 2021, 06:11:02 pm »
Can't actually recommend a solution for lack of parallel port (my CNC has parallel, and a newer setup using USB isn't working yet), but perhaps this page will give you ideas:
https://rckeith.co.uk/mach3-parallel-port/
The main problem with no having parallel is timing, so essentially the motion control is offloaded to an interface board. A search for "MACH3 USB" should turn up quite a few options.
Logged
xzswq21
Kean
Supporter
Country:
Embedded systems & IT consultant
Reply #2 on:
October 11, 2021, 09:41:29 am »
I've used Gecko G540 drives on a number of CNC builds, either with a PC with parallel port (standard or PCI) and Mach 3, or via an Arduino Mega running grbl for the motion controller.
I'd suggest looking at something like the Warp9 Smooth Stepper (USB or Ethernet).
https://warp9td.com/
Or the Smoothieboard if you want something with combined motion controller and motor drivers.
https://smoothieware.org/smoothieboard
Mach 3/4 is good if you want to use Windows, but there are alternative options like UCNC or LinuxCNC.
Logged
xzswq21
beanflying
Super Contributor
Country:
Toys so very many Toys.
Reply #3 on:
October 17, 2021, 08:49:44 am »
My project 1200x600 currently has a
https://planet-cnc.com/
USB 4 axis board on it but before it gets back in running form I am seriously considering a stand alone solution rather than tethered to a PC. Mach3 and or 4 is not really where I want to go either.
So the likely candidate is the DDCS Expert
http://www.ddcnc.com/?m=home&c=View&a=index&aid=154&lang=en
their 3.1 board (still available too) has been around for a couple of years and seems to work well. Still would like to see some more actual user experiences with it but the manual is comprehensive and well written for a Chinese origin product.
Logged
xzswq21
xzswq21
Country:
Reply #4 on:
October 20, 2021, 07:09:19 pm »
I need a 4th Axis without any motor for a milling machine, later I will mount a motor on the 4th axis. Do you have any recommendation?
I found a 4th Axis and a tailstock from WABECO:
https://www.wabeco-remscheid.de/1694.html
https://www.wabeco-remscheid.de/1707.html
or I found another one:
https://www.vevor.com/collections/dividing-head/products/dividing-head-bs-1-6-3-jaw-chuck-tailstock-for-cnc-milling-machine-precisio
Last Edit: October 20, 2021, 07:18:30 pm by xzswq21
Logged
Kean
Supporter
Country:
Reply #5 on:
October 21, 2021, 06:44:15 am »
Make sure that the one you buy will fit and be usable on your machine once mounted and tooling is set up. I made that mistake and have an expensive 6" Vertex dividing head I can't use until I buy a bigger mill. I got a couple of cheap 4" ones now. Also you probably want a model that includes the dividing plates. The Wabeco ones seem to be Vertex which is a good brand.
Logged
xzswq21
Benta
Super Contributor
Country:
Reply #6 on:
October 21, 2021, 08:34:38 pm »
If you really want to use both dividing head
and
tailstock (I've never done it myself on my F1200, only the dividing head), you really need the F1210. Otherwise you have practically no workspace.
Logged
xzswq21
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
