Author Topic: Best tool for cutting off a plastic-flange chunk from inside an enclosure?  (Read 6081 times)
Offline Doctorandus_P
Also, things like a dremel (like) or hot knife are not very expensive. If you go in the direction of a custom jig for this, the put in (an option) for two of those devices so you can cut both tabs at the same time.
Offline coppercone2
if you make a jig put a vacuum cleaner attachment in there too
The following users thanked this post: Ian.M, 5U4GB
