Hi JJ_023,
Thanks so much for your advice! I had given up on the possibility that someone here would give me actual advice to pursue on my initial plan. But now your post was a really positive surprise
I was already started with this. I'm motivated to make this a success whatever it takes.
I have already ground away the main tube that is mounted inside the U shape. I had cut it in the middle to be able to push the ends inside. Like this:
That tube is an inch (25.4mm) in diameter with a wall thickness of 3mm. Shall I do 4130 tube as a replacement? I assume this should not be heat treated, right?
Then I've also removed that mounting stud on the 2nd photo of my initial post. I do think I'm going to buy that Fowler hardness tester, like you suggested and have a local watchmaker help me judge the results of that experiment.
If it is indeed not heat treated. What would be a good alloy steel to have it possibly stronger that what Toyota made? But also as you know meet the toughness and ductility requirements.
Sure I'm going to preheat. For this I'm thinking about a IR thermometer to purchase. One with the emissivity of a surface to be able to adjust. I will determine the emissivity with a comparison with a thermocouple measurement. Do you know if an IR thermometer works well on a sandblasted surface?
