Author Topic: damping compound for ultrasonic cleaning board with crystal?  (Read 2521 times)
Offline coppercone2Topic starter
« on: January 25, 2024, 07:27:44 am »
I have a board that has a nasty dsub connector that I want to ultrasonic clean but it also has a clock crystal on it.
Not terribly attached to that board, but I was wondering, can i stick some silly putty or something on the crystal to protect it so I can dip the connector into the cleaner for maybe 20 seconds?
I am kinda scared to ultrasonic clean the crystals.
Online jpanhalt
Re: damping compound for ultrasonic cleaning board with crystal?
« Reply #1 on: January 25, 2024, 08:32:11 pm »
After an arduous search, I came across this: https://forum.digikey.com/t/ultrasonic-cleaning-of-pcb-s-with-crystals/8814
What is the frequency?
« Reply #2 on: January 25, 2024, 09:58:22 pm »
i think the crystal is 4MHz and the ultrasonic is unknown
But from a physics prospective, putting a sticky putty on the crystal should offer extra protection? Its a through hole part, but flush with the bottom of the PCB.
Should I put a little wad of putty on the bottom too?
I just wanna dip it like 2cm to get the dsub connector.
« Last Edit: January 25, 2024, 10:00:02 pm by coppercone2 »
