I want to make some rubber? bump guards and a handle/tilt stand cover for equipment, that needs to be durable enough to withstand working as tilt stand but also soft enough to make a good grip. Like the thick guards that come on HP equipment.
Not sure if there a castable resin system that can make the kinds of parts I want. Has anyone had success making this ? Things like 2 part silicone resin are too soft and plastidip is too weak. I was thinking like 3/8 thick parts. Unless you can just pour plastidip in a mold, but I suspect that will be warped garbage. Multimeter covers seem to be what I want to make essentially.
