Looking to find a home for my K40 and it's a little challenging to slot it into the existing room layout.
I have shuffled a couple of things around and have an ideal location ... when it's just the box. Add the exhaust air ducting and the thing has to move out from the wall far enough to be a problem. One option is to sit it on a wheeled stand and move it out when I want to use it - but I was thinking of something else.
I was considering an alternative path for the air flow. Instead of going out the back, cut a hole in the bottom of the case to take it out the bottom. I could run the ducting from below fairly easily.
(Dotted line is indicative. Actual location to be properly determined.)
It is clear on the inside...
There is the matter of that reinforcing section, but I had considered running a couple of others which are parallel to the existing one and either side of the cut-out.
Blanking off the rear hole is an obvious move ... and I was thinking a curved piece inside the corner between the top and the back, to help guide the air downwards...
Any thoughts ... good, bad or indifferent?
