For push rods about the best material is PCB substrate, as you can simply design it, and have it milled and shaped for you, and it is very strong in compression and tension, and, being a composite, it is not going to break or deform easily. Otherwise use glass filled nylon, and shape it by you, though it is murder on tool edges, unless you use carbide tooling. The old fashioned method was using bakelite resin, using cloth bonded with bakelite as the material. Strong, insulating, and a half billion tag boards and electrical panels worldwide still in use, at up to 400kV, are testament to the strength and durability.
