Author Topic: Hi, motor vibrating & trying to run when connected to vfd  (Read 2447 times)
Offline nyame
  • Country: cm
« on: October 05, 2019, 06:02:42 pm »
Hello am facing some issues that need help pls, i have ABB ACS350 2.2KW VFD, and 0.33HP 3 phase Induction motor, after setting the parameters as required, and the vfd is set for operation, send power to the motor i wittiness a continues vibration and the motor rotor trying to run,
please what could be the cause and how can this be rectify
will appreciate any help thanks.
Offline mikerj
Re: Hi, motor vibrating & trying to run when connected to vfd
« Reply #1 on: October 08, 2019, 05:36:51 pm »
The symptoms suggest one of your phase windings may be open circuit, either within the motor, in the wiring between motor and VFD or the VFD itself is bad.
Offline CatalinaWOW
« Reply #2 on: October 08, 2019, 07:17:59 pm »
Be sure to double check your wiring.  I have found the circuit diagrams/instructions provide with some three phase motors to be subject to misinterpretation.
Offline jackthomson41
« Reply #3 on: October 10, 2019, 03:47:22 pm »
Single Phase Induction motor needs a new winding. Does it has a single layer or double layer winding, may be you need to just change single layer.
« Last Edit: March 04, 2021, 05:36:58 am by jackthomson41 »
