Author Topic: High temp contact grease  (Read 967 times)
Online coppercone2Topic starter
« on: June 14, 2024, 04:37:14 pm »
My pid oven got a thermocouple disconnect error. I have a ceramic thermocouple adapter in the oven to connnect a probe to the cable. When I replugged it, the error went away.
Is there a high temp contact grease I can use to improve this connection?
I need the adapter because I use a heavy solid wire to route it and a thin stranded probe to measure (I.e. tape to pcb
Re: High temp contact grease
« Reply #1 on: June 20, 2024, 04:18:54 am »
lol, the venus motor document from the other venus thread might be the best source of information on this. they actually tested alot of grease with pictures to show you how it ends up.
Offline mzzj
« Reply #2 on: June 24, 2024, 08:31:31 am »
What thread or pdf you are referring to?
