A PCB eyelet, like from keystone, when depressed with their punches, how tight should it be in a PCB hole?
I did one of the 1/8 inch eyelets using their manual tooling combined with a automatic center punch with an adapter I made. It takes a few pumps but I can flatten them out nicely without tearing.
But anyway, if I mark the eyelet, and grab it with a pair of pliers, I can rotate the eyelet without too much effort (a light grip on small channel locks).
This seems reasonable to me as there are no serrations or anything like that.
Is this correct? Or should a eyelet be anchored more firmly? I don't see any gap when looking at it sideways, and it won't rotate without pliers.
I assume they are meant to be soldered down to the PCB. But I am curious about using them on bare PCB to make say a transformer distribution riveted PCB. For instance this would mean that turret terminals can rotate. Not as conveniant as I thought since it requires a board etch in that case. The best I could do assuming its correct to apply epoxy with a syringe before the swageing.
I thought maybe its possible to put inner crown washers on both sides of the eyelet so it digs into the substrate a little bit. Is this acceptable practice if you get a longer eyelet?
You can use pretty much whatever board thickness you want, which means like a really beefy substrate for magnetic elements, large capacitors, etc. Requires a bit of point to point magic but I like how stiff the substrate is. And since its deformed thick brass, you don't have stupid glue related concerns, vias pulling out, etc. For heavy stuff its just logical.
