Author Topic: Keithley 2450 / 2470 SMU change trigger edge inside a trigger model? TRS  (Read 1077 times)
Offline slow_riderTopic starter
So basically I want to be able and trigger on both edges.
At the top of the file I have this code to trigger on digital in 1, rising edge:
digio.line[1].mode = digio.MODE_TRIGGER_IN
trigger.digin[1].edge = trigger.EDGE_RISING
But it seems that if I insert a similar line to #2 with EDGE_FALLING inside the trigger model it does not do anything.
Anyone knows how should I do this?
Offline thm_w
  • Non-expert
https://www.manualslib.com/manual/1322979/Keithley-2450.html?page=702
trigger.EDGE_EITHER Detects rising- or falling-edge triggers as input.
