Author Topic: Looking for 39-pin Connectors Datasheet  (Read 3824 times)
Online FxDevTopic starter
  • Country: tw
« on: November 09, 2023, 09:55:43 pm »
Hello everyone,
I'm looking for 39 pin connectors and case datasheets or technical drawing in this link. I found some technical drawing but it is not enough for me  :-//
Have anybody these datasheets?
Thanks!
https://tr.aliexpress.com/i/33012322977.html
Offline tooki
Re: Looking for 39-pin Connectors Datasheet
« Reply #1 on: December 16, 2023, 01:50:05 pm »
So… ask the seller?
But realistically, if you need products with proper datasheets and reliable specifications, AliExpress is the wrong place to look.
Offline Infraviolet
« Reply #2 on: December 16, 2023, 08:59:31 pm »
39 pin connecotrs to fit in to some already existing thing which uses them? or 39 pins by free choice? If you're freely choosing the connector on the board you're designing right now and on the thing it connects to then bump up to 40 pins and you'll find loads more options (options with full datasheets provided on their webpages), use the extra pin as an extra ground, or leave it unused.
Online JPortici
« Reply #3 on: December 18, 2023, 09:03:07 am »
should be a SICMA connector but i couldn't find the 39pin variant anywhere in the catalogs, could be an unofficial part but it will probably have the same spacings between big and small pins
