Ok yeah I read you can use indium foil for a thermal material too and that is basically solid. I was just thinking maybe it might behave differently when its frozen solid. It melts instantly if you pick it up.
Don't care too much about life span, I just was making sure its not a bottle neck
why? because its weird as hell to see it turn solid. It comes off really easily too (0 sticking power). But I made clamps with threaded rod to hold these things together
all this stuff is hard to probe BTW. Flow, temperature, pressure all require a shit load of accomodations for low temperature use when you are just screwing around.
