Is it true for all forms of reduction gearbox that if the overall efficiency is <50% backdriving will be impossible (gear teeth would break before input would spin, even with no load at the input), and that if the efficiency is >50% backdriving will always be possible so long as any load on the input shat is minimal? Or does this rule ony apply to worm gear systems which use a sliding wedge contact, and not to more typical bevel/spur/planetary gears which have a rolling contact?
I ask because some differt designs of planetary gears which I've 3d printed have similar reduction ratios, yet if I backdrive one of them even with the motor present the input spins smoothly, yet the other won't backdrive at all (even with no motor present). Does this mean the latter one will have a poor efficiency (<50%) and give a lot less output torque than would be expected from the input torque and reduction ratio?
Thanks
