Author Topic: OV5640 camera connector  (Read 2410 times)
Offline Boris-no-worriesTopic starter
« on: July 02, 2019, 10:02:22 am »
Hi there
I have OV5640 MIPI camera which has what appears to be 24 pin BTB connector surface mounted on FFC cable. The majority of Arduino or RPi cards however work with just FFC cable. I've tried to Google some sort of cable adapter that I could use convert the connector but found no products suitable which is strange. It appears that I am not looking for the right thing.
So I have two questions:
1. What is the name of the connector I have (see the image attached) ?
2. Are there any cable convertors/adapters, etc I could use to connect the camera to a regular flat 24 pin connector?
Thank you
