Author Topic: non reactive paint for silver?  (Read 902 times)
Online coppercone2Topic starter
« on: November 27, 2022, 06:03:08 am »
I have some silver plated objects I want to paint. Its a very thin silver plating.
I thought spray paint would be good, but I am wondering if it can effect the silver plating with the extra stuff in the paint (i.e. rustoleum has corrosion chemistry stuff in it).
should I just use sheet rock paint?
Like self etching primer seems like a bad idea. But regular primer?
« Last Edit: November 27, 2022, 11:09:34 am by coppercone2 »
Offline Nominal Animal
Re: non reactive paint for silver?
« Reply #1 on: November 27, 2022, 11:26:32 pm »
How about acrylic paints, specifically hobby and model paints?  Possibly with a non-etching primer?
Silver itself is quite non-reactive.  The etching is what you want to avoid, so I guess "non-etching" is a keyword to use.
There are model car paints that really have the same look and feel as automotive paints, but you should verify they're okay to use on metals as well as plastics; the primer is likely different for the two.  (Lots of people restore old metal toys, so hobby people are likely to know about this stuff.  Just mention the silver is plated, no need to mention electronics.)  I'd specifically look at the acrylic ones.
Oh, and if you want to protect whatever is under the paint, consider using a lacquer layer.  (Exactly what kind would be good for a plated surface, I don't know, but hobby paint people do; they used to use that kind of stuff a lot when they still made toys out of metal, and they're quite expensive and often restored today.)
« Last Edit: November 27, 2022, 11:31:41 pm by Nominal Animal »
« Reply #2 on: November 27, 2022, 11:51:40 pm »
yeah transformer varnish makes sense I guess
The following users thanked this post: Nominal Animal
« Reply #3 on: November 28, 2022, 05:33:36 pm »
I put regular non etching primer and then liquid electrical tape on it. Nice coating so far.
Offline bidrohini
  • Country: bd
« Reply #4 on: December 15, 2022, 05:57:33 am »
