Electronics => Mechanical & Automation Engineering => Topic started by: strawberry on January 11, 2022, 04:16:03 am
Title: printing on glass
Post by: strawberry on January 11, 2022, 04:16:03 am
print size 700x127mm
not expensive silkscreen printing inks? epoxy?
photosensitive emulsions?
small amounts for storage
Title: Re: printing on glass
Post by: Martin Miranda on January 11, 2022, 04:38:50 am
ask your local sign shop if they have a flat bed UV (ultraviolet) printer. the one that used on souvenirs mugs pens...
the UV printer can print a backlayer (white/black) and top clear coat.
Post by: strawberry on January 11, 2022, 04:56:10 am
opposite side of glass
back layer will block print
I think they dont have that large printers
Post by: SilverSolder on January 11, 2022, 05:23:49 am
Vinyl decals could be cut to that size, would be very cost effective.
Post by: strawberry on January 11, 2022, 09:08:12 am
something like this
Post by: Martin Miranda on January 11, 2022, 01:08:10 pm
that can be done using UV printer. as it can print white ink. i'll look for it. it's silkscreen quality btw.
Post by: Martin Miranda on January 11, 2022, 01:09:33 pm
they can directly print on t-shirts afaik. or as big as few feet. you can youtube uv printer flatbed.
Post by: rpiloverbd on February 22, 2022, 10:54:37 am
Depends on your application and budget. There are many options from digital uv printing to screen printing.
Post by: Domagoj T on April 07, 2022, 09:21:41 am
I did something similar, but on acrylic. I wanted white background with black markings, so I painted entire back side white, then laser engraved the design (and cut the cutouts I wanted), then I filled in the engraved parts with black paint. From the front it looks quite nice if I may say so myself.
[attach=1]
Should you go this way, you may have trouble cutting glass, but the laser will burn away the paint just as well.
