Author Topic: printing on glass  (Read 2737 times)
Offline strawberryTopic starter
  • Country: lv
printing on glass
« on: January 11, 2022, 04:16:03 am »
print size 700x127mm
not expensive silkscreen printing inks? epoxy?
photosensitive emulsions?
small amounts for storage
Offline Martin Miranda
  • Country: ph
  • ~~Work: Electronics~~, ~~Hobby: Electronics~~
Re: printing on glass
« Reply #1 on: January 11, 2022, 04:38:50 am »
ask your local sign shop if they have a flat bed UV (ultraviolet) printer. the one that used on souvenirs mugs pens...
the UV printer can print a backlayer (white/black) and top clear coat.
beach, sun and the island i call home.
https://www.youtube.com/channel/UCOspWWciGGyF5NwmeVT_mWA
  • Country: lv
« Reply #2 on: January 11, 2022, 04:56:10 am »
opposite side of glass
back layer will block print
I think they dont have that large printers
Offline SilverSolder
« Reply #3 on: January 11, 2022, 05:23:49 am »
Vinyl decals could be cut to that size, would be very cost effective.
  • Country: lv
« Reply #4 on: January 11, 2022, 09:08:12 am »
something like this
  • Country: ph
« Reply #5 on: January 11, 2022, 01:08:10 pm »
that can be done using UV printer. as it can print white ink. i'll look for it. it's silkscreen quality btw.
  • Country: ph
« Reply #6 on: January 11, 2022, 01:09:33 pm »
they can directly print on t-shirts afaik. or as big as few feet. you can youtube uv printer flatbed.
Offline rpiloverbd
  • Country: bd
« Reply #7 on: February 22, 2022, 10:54:37 am »
Depends on your application and budget. There are many options from digital uv printing to screen printing.
Offline Domagoj T
  • Country: hr
« Reply #8 on: April 07, 2022, 09:21:41 am »
I did something similar, but on acrylic. I wanted white background with black markings, so I painted entire back side white, then laser engraved the design (and cut the cutouts I wanted), then I filled in the engraved parts with black paint. From the front it looks quite nice if I may say so myself.
1457371-0
Should you go this way, you may have trouble cutting glass, but the laser will burn away the paint just as well.
