No home for this in particular and it is a new product to me. There has been bolt on Metal options for a while but this is now a lost cost alternate for lighter duty applications. So if you dislike long belts on your CNC projects look it up.
Precision plastic and inserts into V-Slot Aluminium
https://www.makerstore.com.au/product/gear-m1-int-500-d/ should be available elsewhere too. Downside is locally they only have 1/4" Pinions to suit NEMA 23 Steppers but I would most likely be running a reduction drive to this so adapting to NEMA X would be easy. Possibly ok for lighter duty routers too but generally there are better options with Ball Screws.
Redesign on my Foam Cutter project is a bit of a no brainer as it simplifies the design a lot and removes 3m Belt runs and the stretch issues that go with it. Seriously now considering a re design of my 1200x800 Laser cutter even though I have all the bits in stock for it.
