Self tapping screws almost invariably refer to screws meant for metal. For plastic it's another story.
Self tapping screws for metal? Never heard of those, maybe you mean self- drilling screws.
From Wikipedia:
"A self-tapping screw is a screw that can tap its own hole as it is driven into the material. More narrowly, self-tapping is used only to describe a specific type of thread-cutting screw intended to produce a thread in relatively soft material or sheet materials, excluding wood screws"
No, Alex is 100% correct.
“Soft material” includes things like aluminum and zinc, and “sheet materials” includes sheet metal, most commonly steel. But that isn’t the whole definition given on the page, either.
Trust me, to us native English speakers (or at absolute minimum, in North America), when we hear “self-tapping screw”, the first thing we think of is sheet metal screws and screws for solid, soft metal (like aluminum), because metals are materials where machine screws can also be used, so the distinction between machine screw and self-tapping screw is fundamental. Because plastics comparatively rarely use machine screws, when we hear “screws for plastic”, we assume self-tapping screws.
In English (and for that matter, in German, the other language I speak at a native level), we never use “self-tapping” to describe screws for materials where screws are
always self-tapping, because it’s redundant. So wood screws, plywood screws, drywall screws, etc. are called just by those names, without needing to specify self-tapping. As I said above, screws for plastics almost fall into this category, since machine screws are seldom used in plastics without metal threaded inserts. So in practice, we really use “self-tapping” as a descriptor for the material where both machine screws and self-tappers are common, and that is metal.
A self-drilling screw is a special subset of self-tapping screws that don’t require a pilot hole.
Anyhow, when searching on AliExpress almost all results for "self tapping screws" are screws intended for plastic.
https://a.aliexpress.com/_oEPXXEP
I can’t believe this needs to be restated so often, but
AliExpress is not in any way indicative of standard English terminology for things. Those are often machine translations, and even when they’re not, they often use terminology that is wildly divergent from the terminology used by native speakers. Additionally, sellers employ tons of “keyword stuffing” to make their listings show up in as many searches as possible, so the keywords used are often not only incorrect, but irrelevant to the product being sold.
And to boot, your claim that “almost all results” for them on AliExpress are screws intended for plastic isn’t even true! Many are wood screws (which, as I explain above, are never called “self-tapping” in English), many are sheet metal, and many do not specify at all — and among those unspecified ones, some look like they’re for plastic, some look like sheet metal screws, and many look like wood screws.
