leaving excessive O2 around in a closed container will likely cause issues with some materials!!
I wonder if a box of silica gel, a heater and some a solenoid controlled vents wouldn't be faster.
Interesting technology, but leaving excessive O2 around in a closed container will likely cause issues with some materials!!
Heater is obviously faster, as was noted in the video, but energy costs are high right now for some countries, so they are avoiding that solution.I'm sure a 3W heater would not work as well as this device.
Its actually a green technology
Carbon comes to mind as something that's cheap and readily oxidizes
Quote from: Marco on February 27, 2024, 10:28:15 pmI wonder if a box of silica gel, a heater and some a solenoid controlled vents wouldn't be faster.Heater is obviously faster, as was noted in the video, but energy costs are high right now for some countries, so they are avoiding that solution.I'm sure a 3W heater would not work as well as this device.
