Author Topic: Dirac Belt Trick Mechanism cleverly avoids twisting wire  (Read 2784 times)
Offline mathsquidTopic starter
  • I like math.
« on: March 17, 2021, 04:45:46 pm »
This is an interesting video I ran across. A cube is turned continuously, but the string attached to it doesn't get twisted.
More info: https://en.wikipedia.org/wiki/Plate_trick
« Last Edit: March 17, 2021, 04:48:47 pm by mathsquid »
Offline Circlotron
Re: Dirac Belt Trick Mechanism cleverly avoids twisting wire
« Reply #1 on: March 25, 2021, 01:10:11 am »
I wonder if you could somehow use that principle to construct a homopolar disc generator or motor that doesn't need slip rings?
Offline domika
  • Country: id
« Reply #2 on: April 24, 2021, 04:29:08 pm »
this is a good project
___________________
nama bayi news
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: April 25, 2021, 01:55:56 am »
Hmm, perhaps.  But is the solution worse than the problem -- how are you going to get all that current out?  Surely not through cables, the amount of flex requires a lot of slack and discourages large amounts of it. :-//
Somewhat related mechanism:
« Last Edit: April 25, 2021, 01:58:55 am by T3sl4co1l »
Seven Transistor Labs, LLC
