Author Topic: Boston Dynamics New Humanoid Robot  (Read 6756 times)
Offline EEVblogTopic starter
« Last Edit: April 18, 2024, 02:19:58 am by EEVblog »
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Boston Dynamics New Humanoid Robot
« Reply #1 on: April 18, 2024, 12:39:53 am »
This stuff is getting pretty awesome. I hope in about 20 years when I need one to take care of me at home it will be a reality.
Offline Kim Christensen
« Reply #2 on: April 18, 2024, 04:19:04 am »
Judging by the scuff marks,  it looks like they've already kicked it and hit it with a stick.  >:D
Also, someone has labeled the left and right elbow joints with felt pen in case it gets dismembered again.
Online Doctorandus_P
« Reply #3 on: April 20, 2024, 01:15:00 pm »
That was from Bosstown Dynamics. That's a whole other company.
Online Infraviolet
« Reply #4 on: April 20, 2024, 03:35:55 pm »
Impressive work on those hip and shoulder joints, does it look to you like they actually do the full 360 degrees multiple times and need slip rings? or not?
« Reply #5 on: April 22, 2024, 06:55:39 pm »
... does it look to you like they actually do the full 360 degrees multiple times and need slip rings? or not?
No way to tell such a thing from the outside. Both the turret of windmills and the inside of a steering wheel of cars are mechanism that can pass electricity over a joint that can do several revolutions by either twisting a cable (windmill) or similar to the spring in a tape measure.
« Last Edit: April 22, 2024, 07:04:11 pm by Doctorandus_P »
Offline W4PJB
« Reply #6 on: May 13, 2024, 12:50:47 pm »
I got a tour of their R&D lab a year go when I worked for one of their suppliers. The entire building is about as wild as you would expect it. And yes, there are robot doggos wandering the hallways everywhere. They're living in the future every day.
