Author Topic: Boring topic - drilling RPM range etc - affordable bench drill, German market  (Read 13503 times)
Online jpanhalt
Re: Boring topic - drilling RPM range etc - affordable bench drill, German market
« Reply #100 on: November 16, 2024, 11:09:39 am »
I presume you kept the original drill press in this thread and cleaned up surface rust with 3M pads or similar.  Rust inside a casting is probably nothing the worry about.  Many cast iron tools will put a red primer on those surfaces.  Otherwise a light oil helps.
I moved to a "hobby" farm when I retired and my heaviest tools went to a barn without climate control.  Originally, I used LPS 3 to protect surfaces from rusting.  It is pretty good.  At the farm, I switched to Kel 132 (Kel is short for Kellogg but has no current relation to the cereal so far as I know).  I like it a better but would use either.  I also keep things pretty well coated with light oil (10 or 20 SAE, non-detergent).  During the dampest months, I run a dehumidifier because the air is hot and humid, and the concrete floor is cooler.  I almost never use WD-40 except for cleaning, never for long-term protection or lubrication.
The following users thanked this post: TinkeringSteve
Offline Njk
  • Country: ru
« Reply #101 on: November 24, 2024, 12:15:11 pm »
For occasional use I quite like the Wolfcraft drill stand with the rack and pinion:
Spot on. It's the most rigid stand I could find. A 40 mm steel pipe column. A German brand. Although the other parts are from aluminum, most other things of that sort are crap by design, of too thin column.
