Author Topic: A hammering machine/drill working mechanism  (Read 709 times)
Offline abdulbadiiTopic starter
« on: December 09, 2022, 11:31:32 am »
How does the hammering machine/drill mechanism work (please explain elaborately with few decent illustrations) ?
Online jpanhalt
Re: A hammering machine/drill working mechanism
« Reply #1 on: December 09, 2022, 11:47:06 am »
There are extensive descriptions on the internet.  Here's one: https://www.protoolreviews.com/rotary-hammer-vs-hammer-drill/#:~:text=A%20hammer%20drill%20is%20simply,a%20vibration%20against%20each%20other.
First step, you need to refine your question:  hammer drill, rotary hammer drill, or impact drill?  Impact drilling is like in the olden days when you used a star chisel and hammer to drill into concrete.  The mechanism was simple.  You hit the chisel with a hammer, rotated it a one eight turn (approximately) and hit again.   Repeat until you had a hole. If you are only drilling a few holes in soft concretious materials like mortar, you can use a carbide concrete drill in an ordinary variable speed hand drill.
The following users thanked this post: abdulbadii
Offline vk6zgo
« Reply #2 on: December 09, 2022, 11:48:25 am »
This might help:
Online Doctorandus_P
« Reply #3 on: December 09, 2022, 04:21:11 pm »
Just search a bit around on youtube.
They have teardowns of about all sorts of tools available on the market.
