Author Topic: custom bump guards on stuff like HP equipment?  (Read 949 times)
Offline coppercone2Topic starter
« on: May 05, 2022, 04:21:45 pm »
I want to make some rubber? bump guards and a handle/tilt stand cover for equipment, that needs to be durable enough to withstand working as tilt stand but also soft enough to make a good grip. Like the thick guards that come on HP equipment.
Not sure if there a castable resin system that can make the kinds of parts I want. Has anyone had success making this ? Things like 2 part silicone resin are too soft and plastidip is too weak. I was thinking like 3/8 thick parts. Unless you can just pour plastidip in a mold, but I suspect that will be warped garbage. Multimeter covers seem to be what I want to make essentially.
« Last Edit: May 05, 2022, 04:23:29 pm by coppercone2 »
Offline thm_w
  • Non-expert
Re: custom bump guards on stuff like HP equipment?
« Reply #1 on: May 05, 2022, 08:56:36 pm »
3D printed TPU is an option.
Its quite a bit stiffer than a multimeter case though, the stuff I have is 95A. I know you can get down to 85A, maybe less, haven't tried that though.
« Reply #2 on: May 06, 2022, 03:03:42 pm »
I see a 85A resin for resin printer. When I meant castable resin I assumed I would have to make a mold, but if you can 3d print this stuff that is fine too, since I have a resin printer and I only want these things on the corners. It should still stand on the rubber feet but protect the box edges.
So you think 85A is the correct number?
https://wanhao.store/products/3d-printing-resin-rubber-resin-1000ml-bottle
https://www.amazon.com/ELEGOO-Water-Washable-Printer-Rapid/dp/B081YSG83N?th=1
« Last Edit: May 06, 2022, 03:06:50 pm by coppercone2 »
Offline thm_w
  • Non-expert
« Reply #3 on: May 06, 2022, 09:11:19 pm »
I don't think 85A is the correct number, just that it is easily available in TPU filament.
Multimeter case might be in the 40-60A range?
https://www.smooth-on.com/page/durometer-shore-hardness-scale/
