Author Topic: What pins are used for breadboard cables?  (Read 1845 times)
Offline YellofriendTopic starter
  • Country: hk
« on: January 17, 2023, 02:58:43 am »
Male and female I need. No need for housing, I can shrinktube them. Right now I use XH for the female, but they a bit bulky due to the locking pin.
TVM802C - now with OpenPnP
T962A
Offline thm_w
  • Non-expert
Re: What pins are used for breadboard cables?
« Reply #1 on: January 17, 2023, 10:15:06 pm »
dupont
But I'm sure you know its cheaper to buy the pre-finished cables.
https://protosupplies.com/product/2-54mm-male-pins/
The following users thanked this post: Yellofriend
  • Country: hk
« Reply #2 on: January 18, 2023, 05:32:03 am »
Thanks.
Dupont was the keyword.
And the promiscuous girlfriend is here:  https://protosupplies.com/product/2-54mm-female-pins/
In China I can find them with 杜邦 (Dupont) + 2.54. And one can add 金 for gold plated if preferred.
My cheap breadboard cable all sort of of oxidized. And the cable is so bad I can't strip it without cutting strands.
A good page about it:  https://www.mattmillman.com/info/crimpconnectors/dupont-and-dupont-connectors/
« Last Edit: January 18, 2023, 06:05:01 am by Yellofriend »
T962A
