Is anymone knows how this material is handling the mechanical stress and the gradients of temperature withing time ?
because the cutting forces needed to cut wood with a 20,000 rpm 1/4 hp router is just not much. a few pounds of force.
If the wood body of their cnc router was twice as thick, and a square closed box section instead of open I beam sections, you could put a 1hp router with nema 34 steppers.
the next thing to upgrade would be the rails and rollers, for just regular cheap 20mm linear rail. then the next thing to upgrade is ballscrews instead of a belt. but all that costs money.
1500$ for a complete system that can do intricate carvings (they just take a long time) can pay for itself in 1 day if you have a customer base.
