Author Topic: [Volt-nut] "HULK" Fluke 5720 calibrator rig build out of random broken boards.  (Read 41177 times)
Offline MadTux
Re: [Volt-nut] Zombie F5720A calibrator build out of random boards.
« Reply #50 on: July 15, 2018, 12:00:04 am »
https://en.wikipedia.org/wiki/Swage_nut
And a bored person with a lathe
Online 2N3055
  • Country: hr
« Reply #51 on: July 15, 2018, 08:34:59 am »
https://eu.shop.bossard.com/group/en/9504/nuts-inserts/insert-nuts/bn-201_hex-self-clinching-nuts
You put it on the other side (like Fluke did) and you tighten it...
Offline TiNTopic starter
  • Country: ua
    • xDevs.com
« Reply #52 on: July 15, 2018, 08:51:44 am »
Those all are not the ones used. There is no thread on original insert but a lip for bolts head. Shield does not hold a bolt, it goes thru , just hiding the bolt head under surface.
« Last Edit: July 15, 2018, 09:07:54 am by TiN »
Online Kleinstein
« Reply #53 on: July 15, 2018, 09:37:27 am »
Does Fluke still sell the shield as a spare part ?  This might be easier than to get one made.
For the bolts, one might get away with just sink holes and mating screws. Not as pretty, but should be easier to get.
  • Country: ua
    • xDevs.com
« Reply #54 on: July 15, 2018, 09:48:05 am »
They did not even reply any of my parts quote requests before, so those were dead end wishes. Service manual implies that you can order parts, but you likely need to be NMI or big known cal lab for them to even spend time replying?
I could just bolt the shield using regular flathead screws, and it can work just fine. It  is just an idea to make it look kinda like real deal that bothers me :). After all this time and funds inversted into this , skipping on little screws feeling like a betrayal :D.
Offline DC1MC
« Reply #55 on: July 15, 2018, 10:07:32 am »
Hi TiN, IMHO you want a set of these guys:
https://apexfasteners.com/fasteners/images/Flush-MountedPanelScrewComponents.pdf
It's true, they have thread on the insert, to retain the screw, but they are so designed that the screw head is flush with the insert, and the threads can be easyly drilled out.
 Cheers,
 DC1MC
Offline e61_phil
« Reply #56 on: July 15, 2018, 11:57:35 am »
My experience with Fluke Calibration is quite good. I had a few questions related to the uncertainties and their calculations of the recently bought 8508A and they answered in a very long detailed email and the contact person also created an excel sheet for me to play with the numbers. I also asked something about the specifications of the 5450A and the 5440B and they answered immediately.
Nevertheless, I bought a new 8508A a couple of weeks before and I asked with my company email.
  • Country: ua
    • xDevs.com
« Reply #57 on: July 15, 2018, 12:27:57 pm »
They'd better answer questions that 22K$ DMM customer asks. :) However I didn't buy any 5700/5720A calibrators from Fluke, so my parts quote requests not justified I guess. :=\.
Attached better pics of the nut.
Offline SteveP
  • Country: ua
    • xDevs.com
« Reply #59 on: July 15, 2018, 05:39:25 pm »
I think this is closest we can get, so I'll go with that.
Since outer covers aren't quite fixable, I also made few CADs for those. Like a bought one, eh?
Let's see how hard would it be to get these manufactured in one off qty.
The following users thanked this post: ManateeMafia
Online Zucca
  • EE meid in Itali
« Reply #60 on: July 16, 2018, 08:05:27 am »
Solid Works?
  • Country: ua
    • xDevs.com
« Reply #61 on: July 19, 2018, 04:02:21 pm »
They are solid :)
Little update today.
Took apart frame parts. Inguard frame is easily fixable, but outguard right wall need some work.
Even plastic guide frames are nearly intact, which is good news. I don't want all those boards floating inside willy nilly.
Also chopped off posts area from old ruined front panel plastic. Compare 57XX post construction :-+ vs 5500A one with shrouded banana receptacles  :--.
I'll trim excess plastic on sides, and make it fit just like glove on my 5500A front panel frame. Should all fit seamlessly.
The following users thanked this post: quarks
  • Country: ua
    • xDevs.com
« Reply #62 on: July 21, 2018, 01:18:59 am »
Today's update, work on posts a bit to get the panel fit.
Condition before:
Condition after on my Fluke 5500A frame.
I had to file 0.3mm for key on the rods to make them fit the original Fluke base. Other the cap plastic color, rest of the LowThermal connector is identical.
USD $175 worth of connectors. Done. :)
The following users thanked this post: Dr. Frank, Zucca, Samogon
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #63 on: July 21, 2018, 09:13:55 am »
Wow, that panel looked like junk but whatever juice you use in your magic wand turned it into practically a new item. Impressive work.
BTW, super jealous of your stuff, I want it all! :D
I'm gonna have to make friends with the local test equipment outlet/reseller here in Akihabara to see what gems I can score from their junk pile..
« Last Edit: July 21, 2018, 09:40:21 am by TERRA Operative »
Online Zucca
  • EE meid in Itali
« Reply #64 on: July 23, 2018, 07:18:53 am »
Midas touch
  • Country: ua
    • xDevs.com
« Reply #65 on: July 24, 2018, 04:46:54 pm »
After few days of bang-bang smash-smash, I got main chassis parts somewhat straight. Today decided to do a test fit and start assembly of the frame.
Here are few shots from today's timelapse footage.  ;)
The cage didn't suffer much damage, and its geometry is acceptable. A3 and A4 motherboards align well.
Couldn't resist, and plugged all (almost) my inguard PCBAs inside to make sure all slides nice. No issue here, yay :)
Now time for heavy mains transformer frame and cooling fans. You can see transformer repaired wiring (previous owner chopped wiring right off :)).
Now test fit with front panel assembly.
Outguard PSU and CPU cards install nicely too.
Like some said - there is distant light in the end of this XXXXX$ USD tunnel :D.
« Last Edit: July 24, 2018, 10:42:12 pm by TiN »
Offline branadic
  • Sounds like noise
« Reply #66 on: July 24, 2018, 06:19:21 pm »
Congratulation to an almost finished investment. At the end, how much money did you safe compared to a fully functional but used unit?
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
  • Country: ua
    • xDevs.com
« Reply #67 on: July 24, 2018, 09:37:16 pm »
I paid more than few recent sold ones on eBay, but I also get extra goodies too and few multiple boards to tinker with. It is also not one big payment but spendings over two years since I started collecting bits&pieces. If you want a unit, go buy used one, obviously. I knew from the start that it would be even or more $ than used box.
Anyhow, it's a learning process and fun that matters for me, and I'm happy to be able to do it. If you factor in cost of time , then most of "good deals" of broken T&M are more expensive than complete working units, but we still do it, right? :)
The following users thanked this post: SeanB, Zucca, Muxr, dl1640, FransW
Offline Dr. Frank
« Reply #68 on: July 24, 2018, 10:25:50 pm »
Illya,
yep, the end of the tunnel comes closer..congratulations, and again - well done.
In the old days, it was quite easy to get old and damaged equipment for a bargain, with an easy fix.
Even from the US, including tax and VAT, it was possible to get top notch test equipment for a very low price.
Today, it's not that easy any more, up to impossible, maybe also due to the revival of DIY electronics and metrology instruments, by the eevblog effect..
Anyhow, I really appreciate very much all your re-engineering work you've done and that you're still doing.. and probably spending all your income on that stuff..
It's fun for you, for sure, but also a big knowledge benefit for everyone in this community.
And a big fun for me, also, to follow your progress.
At last, I just want to point to your unique final conclusions and categorization of the 3458As minor and major faults (U180!) .. that has helped a lot many people..
Ok, I think that's enough of ultimative adulation .. get this thing running, finally!
Frank
« Last Edit: July 24, 2018, 10:28:02 pm by Dr. Frank »
The following users thanked this post: ManateeMafia, Zucca
Offline dl1640
  • Country: cn
« Reply #69 on: July 29, 2018, 04:21:27 am »
old A18 can go bad easily due to CC resistors in PA supply section
just my experience, if A18 is too dusty it would cause output tripped if set value above 20V, and we get errors from A14~A16.
  • Country: ua
    • xDevs.com
« Reply #70 on: July 29, 2018, 07:21:41 pm »
Initial chassis works done, so I decided it's time to test fit stuff and give it a smoke test.
There is still some bang-bang smash-smash work need to be done on the rear right corner, to get sh`t align properly, but I don't have patience to deal with that now.
So minimal set of boards installed, to allow me repair and do some checks on inguard A18 regulator board (yes, one that got carbonized by carbon resistor and have drilled holes now  :-/O).
After few hours of jumpwiring and checking, I've got it working. No smoke and blown parts so far, yay!
Positive PA+ 375VDC output:  :-+
Negative PA- -190VDC output.  :-+
Tomorrow last piece arrives, so I'll continue to check regulator rails and voltages, and once all is good, will fit all boards in and see if the Hulk chuch.  :scared:
The following users thanked this post: quarks, e61_phil, kj7e
Offline ManateeMafia
« Reply #71 on: July 29, 2018, 07:27:10 pm »
TiN,
Great job so far. I know you can't wait to run its first calibration.  :popcorn:
  • Country: ua
    • xDevs.com
« Reply #72 on: July 30, 2018, 04:51:49 am »
Received my bad A8 today (good A8 I had before had to go as part of chassis trade  :P) .
Hybrid ceramic assembly looks good, rest I can repair easily.  :-DD
So excited, my hands are shaking! (better not when probing 565 volts on A18!)  :scared:
Offline dl1640
  • Country: cn
« Reply #73 on: July 30, 2018, 05:20:00 am »
saw the light.
such an epic.
  • Country: ua
    • xDevs.com
« Reply #74 on: August 01, 2018, 04:51:28 am »
 :popcorn: Yes, all boards are in (except 30MHz WB option, that is next step).
Sorry for ugly photo, just a quick shot, as I went to bed after 4am tonight. This thing sucking my life out.
Who can sleep anyway when there is 5720A in the room?  :-DD
And after few days of mangling with random non-documented diagnostics errors and swapping my spare cards, I finally have Hulk running.
Finished ACAL last (this) night, and now it is running thru paces with HP3458B.
Next step is to fix my wideband option board set (it trips output to standby in 12kHz-1.2MHz range, but works fine in 1.2MHz-30MHz range), and wait for some parts to arrive, like metal covers and random bits.
Then I'll have it fully assembled and be on 30-day calibration interval versus my 10K/10V/1ohm/4920M standards, to check if there are any hidden rabbit holes awaiting.
« Last Edit: August 01, 2018, 04:53:03 am by TiN »
The following users thanked this post: quarks, doktor pyta
