The thing which these integrated matched monolithic transistors provide, besides matching and good hfe over a wide current range, is low base spreading resistance which allows for lower noise. Some discrete transistors also have low base spreading resistance, including transistors with "perforated" and "ring" emitter construction. The old Zetex "super e-line" transistors would be good, and I am guessing modern high hfe and low Vce saturation parts from other manufacturers. I think Microchip makes the Zetex parts now.
THAT Corporation has matched quads, but I do not know what kind of construction they use.
Linear Systems has duals, but I do not know if they have low base spreading resistance.
