Author Topic: 2465B CTT calibration question  (Read 1531 times)
Offline mmasedaTopic starter
« on: January 01, 2018, 03:26:42 am »
I need to run the CTT calibration routine to remove an error message but I don’t have pulse and time-mark generators.   I have several function generators, signal generators, and 1MHz and 10 MHz TCXO.  Can any of these be used to run the routine?
« Last Edit: January 04, 2018, 12:15:45 pm by mmaseda »
Offline SoundTech-LG
Re: 2465B CTT calibration question
« Reply #1 on: January 03, 2018, 09:22:14 pm »
I really suggest you get the recommended equipment to run the cal. I tried using other equipment with very limited success. Once I got the right gear, it was pretty easy.
« Reply #2 on: January 04, 2018, 03:58:39 pm »
Thanks to those that replied. I was able to perform the calibration by just using a 1MHz 1v peak to peak signal from a TXCO.
« Reply #3 on: January 04, 2018, 09:56:15 pm »
Making some sort of adjustment to get it to pass power on testing is certainly possible using a 10mHz
TCXO output signal, performing a critical calibration is certainly another thing altogether. I doubt Tek would suggest the equipment listed unless there was a pretty good reason to not follow their suggestion. If it passes the power on test though, hey, maybe you got lucky. :)
