Thank you for the reply, I will run the verification tomorrow. Since I only have two of this meter, I was too lazy to write a script for it, but for the flatness adjustment, there are ~ 100 steps total, so I probably should automate it.
Also, For the DCA adjustment, in the high current range, (1A and 2A) the read out will shift for 15 min before stabilize (assume is the CSR heat up causing drift) , so do you do spot calibration or you wait 15 min for each step ?
