Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
3458 A5 board... what is U102, the 8pin DIP?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 3458 A5 board... what is U102, the 8pin DIP? (Read 1509 times)
acts238willy
Regular Contributor
Country:
on:
November 24, 2019, 07:06:19 pm »
In the xdevs 3458 teardown/repair post, I noticed that the 'new' short SMT A5 board still has an
8 pin DIP in a socket... U102. What's with that? They couldn't roll it into one of the ASICs? I only
have the long boards in my 3458s and there doesn't seem to be a similar PDIP.
What does U102 do in the new short A5 board?
Logged
bsdphk
Regular Contributor
Country:
Re: 3458 A5 board... what is U102, the 8pin DIP?
Reply #1 on:
November 24, 2019, 08:01:19 pm »
It holds the configuration bits for the FPGA
Logged
acts238willy
ScoobyDoo
Regular Contributor
Country:
Reply #2 on:
November 24, 2019, 08:20:58 pm »
The PROM configures the FPGA and one version supports 3458A option -001
In such case extra address lines are configured which activate extra memory option -001
Logged
acts238willy
acts238willy
Regular Contributor
Country:
Reply #3 on:
November 24, 2019, 08:55:15 pm »
So if the 8 pin PROM is left out, does the whole board stop, due to lack of instructions..
OR
Does the A5 board operate fine, just not having option 001?
Logged
martinr33
Frequent Contributor
Country:
Reply #4 on:
November 25, 2019, 01:02:48 am »
No FPGA bits means that the board won't work.
There are two different versions of the short board, and for some reason they use different configuration EEPROMs. You can buy the memory upgrade for the later version for somewhere around $30, but the EEPROM for the earlier boards is not available.
Strangely, the new version of the board with upgraded memory was cheaper than the non-upgraded version, but that appears to have changed as both versions map to a lead-free replacement - which is what I would guess is in the black machine:
https://www.keysight.com/my/partDetail/03458-66675
Upgrade chip:
https://www.keysight.com/my/partDetail/03458-88810
There's also an LF ADC listed, but only for factory upgrade.
https://www.keysight.com/my/partDetail/03458-66523
Logged
acts238willy
ScoobyDoo
Regular Contributor
Country:
Reply #5 on:
November 26, 2019, 04:31:53 am »
Hello
The PROM configures the FPGA and needs to be installed - otherwise the FPGA content is empty
There have been two versions of the A5 board (using the yellow STM SNAPHAT batteries), there is an ERC label on your board as legend.
The older A5 boards used one of the (03458-88807/03458-888
08
) and the later boards (03458-88809/03458-888
10
) ODD = basic /
EVEN
= -001 option
The earlier A5 boards needed (undocumented) 03458-88808 PROM as -001 upgrade - the more recent boards use listed 03458-88810 (online available)
Which one you need depends upon ERC number of your board (& S/N unit) and KS Loveland USA most likely can help you with 03458-88808 if you provide
them correct info of your unit (ERC label + S/N°). This is also only difference between a standard unit and unit with -001 memory option.
It is recommended to contact your regional KS service center or KS Loveland USA to guide You to identify and order correct part ...
The part itself cost less than 30€ (USD) and comes with a label that you should glue on the board to notify service engineer it has been upgraded.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Metrology
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
