Author Topic: WinGPIB - Windows GPIB App (multi-purpose)  (Read 217773 times)
Offline enut11
  • Love building/modifying/restoring test equipment
Re: WinGPIB - Windows GPIB App (multi-purpose)
« Reply #650 on: October 03, 2023, 09:32:51 pm »
Hi Ian
I am running Ver 3.26 logger. When I print out the screenshots saved via the chart screen, the black background almost completely obliterates the graph lines.
Is there a way to get a printer friendly output on paper?
enut11
PS
The screenshot does not capture the PPM scale on the RHS
« Last Edit: October 03, 2023, 09:49:08 pm by enut11 »
an electronics nut from wayback...
Online IanJTopic starter
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #651 on: October 04, 2023, 09:33:30 am »
Hi Ian
enut11
PS
I fixed a screenshot bug a few Revs back where it wasn't capturing everything on screen. I'll look at the PPM scale.
I'll see if I can offer different colours for the chart so they print better.
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
  • Country: scotland
    • IanJohnston.com
« Reply #652 on: October 04, 2023, 12:13:51 pm »
New version in Post #1 available for download.
WinGPIB_V3_114_full.zip - Fresh install
WinGPIB_V3_114_updated_exe.zip - Updated exe to replace existing
[Virus scanned using BitDefender AntiVirus]
I have added a checkbox per below to toggle the PlayBack Chart graph background from dark to light. This should assist in printing screenshots.
I have also verified that the PPM scale is captured correctly on screenshots.
Ian.
The following users thanked this post: enut11
  • Country: scotland
    • IanJohnston.com
« Reply #653 on: October 04, 2023, 03:08:42 pm »
WinGPIB_V3_115_full.zip - Fresh install
WinGPIB_V3_115_updated_exe.zip - Updated exe to replace existing
Small adjustment to make the Y-scale interval match the Y-scale grid on the PlayBack Chart.
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #654 on: October 04, 2023, 05:53:20 pm »
WinGPIB_V3_116_full.zip - Fresh install
WinGPIB_V3_116_updated_exe.zip - Updated exe to replace existing
On the 'Light' mode of the PlayBack Chart I have made more of the background white so the whole form can be printed more easily.
Ian.
Offline enut11
« Reply #655 on: October 05, 2023, 05:51:26 am »
Hi Ian
Thanks for the quick response to my screen shot problem.
I did a fresh install of WinGPIB_V3_116_full.zip and ran into program running problems.
Running the desktop shortcut WinGPIB.exe immediately gives the attached error.
If I ignore the run error, I can create a device but the data log/csv window is totally unresponsive.
enut11
« Last Edit: October 05, 2023, 05:53:09 am by enut11 »
  • Country: scotland
    • IanJohnston.com
« Reply #656 on: October 05, 2023, 07:58:18 am »
Hi Ian
enut11
The path on the pop up, make sure it exists and there is a log.csv file in that location. Create it manually if you have to.
A few folks have had this error and creating the path manually and popping the file in there usually fixes it.
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #657 on: October 05, 2023, 04:10:25 pm »
WinGPIB_V3_117_full.zip - Fresh install
WinGPIB_V3_117_updated_exe.zip - Updated exe to replace existing
Slight tweak to the PlayBack Chart Light Mode colours.
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #658 on: October 06, 2023, 05:49:45 pm »
WinGPIB_V3_118_full.zip - Fresh install
WinGPIB_V3_118_updated_exe.zip - Updated exe to replace existing
I have re-written the PlayBack Chart X-Axis labels (that show the minutes).
This was quite a re-write and now uses the built in MSChart X-Axis labels rather than my home grown ones.
As such, they are now located at the bottom of the graph and tie in better with the chart grid.
Making it work with the zoom buttons and the dual device CSV was quite a feat....for me anyways!.....it reminds my why I did the home grown version originally!
I also tidied up the display form, code and fixed some bugs, all related to the PlayBack Chart.
Ian.
« Last Edit: October 06, 2023, 06:15:59 pm by IanJ »
The following users thanked this post: wolfy007
  • Country: scotland
    • IanJohnston.com
« Reply #659 on: October 07, 2023, 11:45:46 am »
WinGPIB_V3_119_full.zip - Fresh install
WinGPIB_V3_119_updated_exe.zip - Updated exe to replace existing
Small bug fix, the PPM scale on the PlayBack Chart wasn't lining up properly with the main chart area.
This is still a home grown scale due to limitations of the MSChart scale functionality.
Ian.
« Last Edit: October 07, 2023, 12:48:08 pm by IanJ »
  • Country: scotland
    • IanJohnston.com
« Reply #660 on: October 08, 2023, 09:02:00 am »
WinGPIB_V3_120_full.zip - Fresh install
WinGPIB_V3_120_updated_exe.zip - Updated exe to replace existing
Very small layout changes to the PlayBack Chart. A wee tidy up.
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #661 on: October 08, 2023, 04:35:48 pm »
WinGPIB_V3_121_full.zip - Fresh install
WinGPIB_V3_121_updated_exe.zip - Updated exe to replace existing
A bit of PlayBack Chart code optimization & tidy up resulting in slightly faster loading CSV files.
When you're not a Pro coder it's too easy to repeat code all over the place and to do things a little long winded!
Ian.
The following users thanked this post: coromonadalix
Online Rax
« Reply #662 on: October 10, 2023, 12:53:30 pm »
Ian,
I tried to use this with a USBGPIB ("xypro"s, I think), and was not able to make it recognized by the program. Are there plans to integrate it into the app?
Or maybe there are solutions for that already I am not aware of.
  • Country: scotland
    • IanJohnston.com
« Reply #663 on: October 10, 2023, 02:35:08 pm »
Ian,
WinGPIB is a layer above the necessary GPIB driver layer, therefore you need drivers loaded for it to work.
- VISA
- GBIP:ADlink
- GPIB-488
- COM port
The most common being VISA and on Windows you would need the Keysight IO Libraries Suite installed.
Generally, get a GPIB interface working with it's own driver suite, test comms to a connected DUT and once working then try WinGPIB.
I've kinda generalised as I am not sure what USBGPIB you are referring to.
Ian.
The following users thanked this post: Rax
Online coromonadalix
« Reply #664 on: October 10, 2023, 03:48:30 pm »
for the xypro's  usb gpib
there was a case of name declaration v6 ....  which i did complain about to make it work with some prologix tools,  it was my case,  just changed the id declaration and started to work on a 34410a,  but i don't have it anymore, i'm waiting for an hioki   ....
https://www.eevblog.com/forum/projects/ar488-arduino-based-gpib-adapter/msg4512557/#msg4512557         post #878 or around it
you can use Rhode Schwartz visa tools  (RS_VISA_Setup_Win_5_12_10.exe)  too instead of the keysight ones  ...  lightweight and  you have tester 32 and 64 bit  to help you do some communications tests ....
Q: for the creator,  is it possible to start it with only 1 instrument / device  instead of 2 ???   is there a setting ??   it's been a while  since i used this software
« Last Edit: October 10, 2023, 05:19:34 pm by coromonadalix »
  • Country: scotland
    • IanJohnston.com
« Reply #665 on: October 10, 2023, 07:45:42 pm »
Yes, you can start either DEV1 or DEV2 or both. Look at the main screen and you'll see option buttons for these.
"CONNECT TO I/O DEVICE 1"
"CONNECT TO I/O DEVICE 2"
"CONNECT TO I/O DEVICES 1 & 2"
Ian.
« Last Edit: October 11, 2023, 01:28:51 pm by IanJ »
« Reply #666 on: October 12, 2023, 01:43:42 pm »
hi thks for the answer    sorry im native french
some comment
i meant to have only 1 device shown  to have a less wide / get a narrower window
instead of  the 2 devices page who is wider   ...
i want to use it on a lappy  but screen size is not practical   loll everything is getting very small ...
thks a lot
oh  the instrument definitions or models ?  are they hard coded in your executable or defined in the config file  next to it ?
oh i saw the GPIBchannels text file
I want to try an hioki bench dmm
« Last Edit: October 12, 2023, 01:54:13 pm by coromonadalix »
  • Country: scotland
    • IanJohnston.com
« Reply #667 on: October 12, 2023, 03:32:13 pm »
some comment
thks a lot
The app size is fixed I am afraid. I could 'cheat' and allow re-sizing thus hiding parts of teh GUI, but it's not reall a good way.
I can probably lose about 6% of it's width only if I tried.
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #668 on: October 12, 2023, 04:20:38 pm »
WinGPIB_V3_122_full.zip - Fresh install
WinGPIB_V3_122_updated_exe.zip - Updated exe to replace existing
Have made the main GUI slightly smaller (width) to help fitting on low res screens.
Not by much mind you, but every little helps.
Ian.
Offline wutieru
  • Country: cn
« Reply #669 on: December 10, 2023, 04:23:47 am »
There are two bugs:
1/ Live Chart TAB SCREEN
when Y-axis scale max is same as Y-axis min, the trend will stop until program restarts.
2/When the text scaling on the monitor is greater than 100%, all text cannot be displayed properly.
by the way,Can you share the communication protocol for temperature  & RH sensors?
  • Country: scotland
    • IanJohnston.com
« Reply #670 on: December 11, 2023, 07:21:59 pm »
WinGPIB_V3_123_full.zip - Fresh install
WinGPIB_V3_123_updated_exe.zip - Updated exe to replace existing
Fixed a problem when changing the Y-Axis Scale Min/Max where it could crash WinGPIB.
So now if you try to enter a Max value equal to or less than the Min value then it won't allow it, it will force a valid value.
Similarly for the Min value entry.
Note:
I checked the Visual Studio form settings and "AutoScaleMode" is already set to "none" so should not be affected by changing Windows scaling......however, this is actually a minefield so not much more I can do. WinGPIB was designed to use 100% scaling.
Ian.
The following users thanked this post: croma641, wutieru
Offline wutieru
  • Country: cn
« Reply #671 on: December 12, 2023, 07:01:42 am »
On the Temp./Hum. page
The stop button is invalid.
and my display page is as follows:
Please pay attention to the bottom line.
  • Country: scotland
    • IanJohnston.com
« Reply #672 on: December 12, 2023, 01:07:31 pm »
The STOP button on the Temp/Hum tab disconnects the serial port when it's connected to the serial Dogratian temp/Hum sensor.
The protocol is available here: https://www.dogratian.com/index.php/sensors/usb-tnh-sht30
Looks like you are not running an English configuration of Windows and it is having some affect on the scaling and also the font being used.
The bottom line is cut off because there is an issue with the TABS at the top of the form, i.e. there should be 1-row of tabs, but on your display the last two have rolled around to a 2nd row and thus is shifting everything down. I think caused by the font issues on non-English Windows config.
This can be fixed but it's a big job and unfortunately I can't do this:
- Use Resource Files for Localization
- Set Font Properties Programmatically
- Handle Form Scaling
- Test on Different Windows Configurations
- DPI Settings
- Provide Font fallbacks
- Use Anchors and Docking
So, all I can do is offer your some guidance on how you can fix the issue on your own PC. One or more of the following may help:
Adjust System Font Settings:
Users can try adjusting the system font settings on their Windows machine. They can go to "Settings" > "System" > "Display" > "Advanced display settings" and adjust the font size. However, keep in mind that this may affect the entire system, not just WinGPIB application.
WinGPIB uses "Microsoft Sans Serif" for 99% of the fonts.
Check Regional and Language Settings:
Ensure that the regional and language settings are configured correctly. Users can go to "Settings" > "Time & language" > "Region" and "Language" to set the desired language and region.
Check DPI Settings:
Users can check and adjust the DPI settings on their machine. This can be done in "Settings" > "System" > "Display" > "Advanced scaling settings." They can also right-click on the desktop, select "Display settings," and adjust the "Scale and layout" settings.
Update Graphics Drivers:
Ensure that users have up-to-date graphics drivers installed. Outdated drivers can sometimes cause display issues. Users can check for driver updates through the device manager or the manufacturer's website.
Check for Windows Updates:
Ensure that users have the latest Windows updates installed. Updates may include bug fixes and improvements that could impact the behavior of your application.
Ian.
« Last Edit: December 12, 2023, 01:17:23 pm by IanJ »
The following users thanked this post: wutieru
  • Country: scotland
    • IanJohnston.com
« Reply #673 on: December 13, 2023, 08:31:49 am »
If you don't like this way of working send your complaints to Dog Rat Ian Johnston.
Not sure what you meant by this.
Ian.
Offline TonoT
« Reply #674 on: December 23, 2023, 08:27:31 pm »
I'm trying to get this software working on my HP3457A and Racal DANA 1992.
Browsing through the messages here, I noticed that there seems to be issues in retrieving data from it.
Please know (if not yet known) that this device is stubborn: it's not using EOI, but it's replies are ALWAYS just 21 bytes (CR/LF included). Nothing signaling data is available.
All commands starting with R just return 21 bytes (indeed results are prefixed). It seems that you can only read exactly 21 bytes using read_bytes().
Please refer to this site:https://tomverbeure.github.io/2022/12/18/Setting-Up-a-GPIB-Communication-with-a-Racal-Dana-1992-Counter.html
That site got me up and running with some simple commands (RUT,RGS etc, yet the STB part that is explained there didn't work for me)
