Author Topic: 3458a updates and drift checking  (Read 1452 times)
Offline EE4allTopic starter
« on: October 09, 2024, 03:19:14 am »
Here is my take on the 3458a updates.
I have replaced:
-Inguard supply electrolytic capacitors
-Outguard supply electrolytic capacitors
-Line filter
-Rifa capacitors
-Added sockets
-Settings FRAM installed
-Firmware updated
-Added option 001 memory
*The ZIF socket required moving 1 resistor and 1 capacitor to the underside of the board. I will be doing various projects with this one, so wanted the cal RAM easy to swap.
*The cal SRAM has been backed up to PC
To Do:
-New fan
-Put labels on the firmware chips on top of the aluminum window covers
-Source a fuse binding post that is missing
-FRAM board for the cal socket, or just punt and put a new Dallas SRAM in for now Installed via a socket adapter
-5000 different volt nuttery tests and  fun times starting with drift tests
-To be continued...
Look at the date code on this old Dallas chip.  8) It's still holding the data.
« Last Edit: October 12, 2024, 11:55:03 pm by EE4all »
The following users thanked this post: Mickle T.
Re: 3458a updates and drift checking
« Reply #1 on: October 12, 2024, 11:43:27 pm »
Calibration SRAM replaced with FRAM and stacked socket adapter. I used 26 gauge magnet wire "inside" the adapter. The 28 pin FRAM socket has extra tall pins, so this gives the bit of space needed. I might have some boards made at some point but this works quite well.
« Last Edit: October 12, 2024, 11:46:05 pm by EE4all »
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #2 on: October 13, 2024, 02:42:44 am »
You can download the gerbers for my Cal board Pcb, see the video description of my video below.
There's a couple of different versions depending on whether you want to use an SMD or TH FRAM IC.
https://youtu.be/cAA1TCvwhuw?si=qWiON_Jy2flO4Ut3
Go to @5:37 for the Calram
EDIT:
Just incase anyone asks, my 3458A was built in 2000 but I replaced the front panel with a new one from Keysight UK a few years ago. I still have the HP branded front panel.
Ian
« Last Edit: October 13, 2024, 09:43:09 am by IanJ »
Website: www.ianjohnston.com
« Reply #3 on: October 13, 2024, 01:10:45 pm »
Thanks, Ian! I had already downloaded your files for this actually, and I will get a few made. I was anxious to get the FRAM going in the meantime with supplies that I had on hand.
Now I will leave it running, as I have no idea how long it was unpowered before I received it.
I will begin logging some data soon, and have your WinGPIB set up as well.
The following users thanked this post: IanJ
