Hi max-bit,
You want me to start up my 3458A to indicate that the battery voltage is 3.025678V and then communicate this here....
3.02V is about it and to me that means the battery is at the end of its life after 12 years of use.
I had of course already done a search, but there is damn little technical information to be found of these generators.
Also in the latest manual I downloaded today from RS, I could not find anything about replacing the CR2032 battery.
I have three other function generators, so I can just try it, and if it goes wrong, too bad....
Reverse engendering doesn't seem like a good idea to me, is going to take way too much time, with the chance of something breaking.
I'm in no hurry to do this, so wait a few more days to see if some one has more information. and will report here how it went.o be sure.
I am also going to copy the "Device Settings" to a USB stick, just te be shure, and will report here how it went.
I can tell that the generator is nicely built, nice PCBs and well shielded power supply.
The internal coax cables are of the Teflon type.
Thank for the reply
Regads,
Bram
