Author Topic: 6x lab standard precision resistors  (Read 3032 times)
Offline JesterTopic starter
« on: May 03, 2023, 09:34:28 pm »
Can anyone venture a guess as to what these six resistors are worth?
I'm going to put them on eBay and want to list them for a fair price.
Much appreciated.
Offline TUMEMBER
Re: 6x lab standard precision resistors
« Reply #1 on: May 04, 2023, 09:14:31 am »
It depends on what evidence of "quality" of these resistors you have. Do you have valid calibration certificates for each of them? Do you have a high-class meter with which you measured each of them in reference conditions? Their status is currently "unknown". You can ask for a high price, but you will not find a willing buyer. These types of resistors are quite popular on ebay. Prices from $250 are not unusual. But they generally have some known "life history" - generally "news from the factory are sold out".
Take a look at how others offer and how they document the quality of their items.
https://www.ebay.pl/itm/225505308948?hash=item348129f114:g:U~8AAOSwpKRkJ0kY&amdata=enc%3AAQAIAAAAwBJ7Bhfd2MiNUYV6LKJcVqctIjgb0wBtxddiK7Wx82fchl1xxNZkjtS6qtLZwydu2GLgJLotnB%2Ft4oLyRuMvq7xg5dSObLNXLY9FHiI0zcELlhwVgnIiGlpf2mh98HQKEE4yAr9W1%2FupLd51sdeh80U4H5BUt%2FqlpmfKl0BMg4LMuhiSgSBYif6Zh9OxpXff7H%2BW8zqNS6Sj%2F4nnotopTlpQcFk98w414HS316HGbs5dShVB6twtvgrp%2F%2FRSBGbZ5g%3D%3D%7Ctkp%3ABk9SR9ij1N78YQ
https://www.ebay.pl/itm/271930151419?hash=item3f504cd1fb:g:X8oAAOSwLVZVpZVU&amdata=enc%3AAQAIAAAA4C5y63oc%2BveuZVsLZbtqOTrTm%2F9kqA2oMHonR0YKiskYe2dD8liSu82SfxzXK9J6Tbpiyem2319r4llTMuLjpzDIiXZMwGibhaxGj4u6vdugLBFmA%2F8BqIvQ67xRzim25xE%2FHwiXoSaUbnPaF6ui6QNf1S8aktsCSMwlgxT6wCnLiPfZXyYO8c5eht3oQv0RNd4E7KJAF%2FPsg4VHJI2WD%2FEC2ZGzv85lIVt%2BborpaDuEa6F7w0VdMcw0f8tgJLTaMswntTtSABXf%2F6ljHdRVdzDRC9KwEDOEVl8wRGCyiq9i%7Ctkp%3ABFBM_uGo3_xh
https://www.ebay.pl/sch/92074/i.html?_from=R40&_nkw=standard++resistors&LH_TitleDesc=0&LH_PrefLoc=2
Online Arhigos
  • Country: gr
« Reply #2 on: May 04, 2023, 10:22:18 am »
Old USSSR garbage, pretty much useless for today.
Typical cost would be between $20- $100 for each one.
The following users thanked this post: Jester
Offline manganin
« Reply #3 on: May 04, 2023, 10:49:21 am »
Condition, condition, condition.
Those Krasnodar type standard resistors can be very good, but the quality varies a lot. You may need to buy ten to get one decent. And in real life the seal is far from hermetic, so nowadays it is hard to find anything not ruined by bad storage.
« Reply #4 on: May 04, 2023, 04:04:17 pm »
Unfortunately I don't have any documentation, I was told they were surplus from NRC Canada. I guess I will price low and see what happens.
Offline guenthert
« Reply #5 on: May 04, 2023, 04:25:49 pm »
Well the $250 (asking price) for the ones from Ukraine were for a set of 3 (looks like a good deal to me).  The one for 6000 sloty (Poland isn't using Euro?) is a Tinsley (originally made for a 5ppm match, compared to the 100ppm for the soviet ones).
I doubt metrology labs are buying from random sellers on the secondary market (I'd guess they might buy a competing lab's equipment when that goes out of business).
Such resistors are made for operation in an oil or air bath as they tend to have a fairly high temperature coefficient (they are optimized rather for long time stability).  Only the most affluent or dedicated hobbyist (some of which you find here) have access to those.
Tip: characterize those resistors yourself and publish your findings here.  That sure helps charging a premium.   ;D
Offline TUMEMBER
« Reply #6 on: May 04, 2023, 04:51:35 pm »
Yes, you're right Poland has (still) its own currency, Polish Zloty. Despite the fact that we are "economically associated" in the EU. And one more thing - these resistors are Russian because they were produced in the USSR. Do you think Texas is an independent Country? Such a "country" at that time was the Ukrainian REPUBLIC - it did not have an independent statehood. By the way, Russian resistors in "good classes" did not significantly differ from the "western ones". They weren't just as accessible, hyped up and exorbitantly expensive as...the physics and materials they are made of are the same everywhere.
Sorry, the text was created with the help of google translate. It certainly only partially reflects what I wanted to convey. :phew:
« Reply #7 on: May 04, 2023, 08:54:36 pm »
The guy stated they were used in an oil bath.
I have no idea what type of meter or bridge they used to measure the value in the second image, but that is a lot of digits and way way beyond my 6.5 digit Agilents resolution. Obviously NRC would have some pretty crazy metrology equipment. We actually live a stone throw from the sprawling main headquarters complex and a builder wanted to build a condo about 1km away that would require blasting for the excavation, apparently the condo project got nixed because of the potential effects from the vibrations on some of NRCs sensitive equipment.
« Last Edit: May 04, 2023, 08:59:32 pm by Jester »
Offline czgut
« Reply #8 on: June 26, 2023, 03:56:52 am »
This resistors are made of Manganin. That means that temperature coefficients will be between -10ppm/deg and +12 ppm/deg in 18°C ..30°C range. (ppm = part per million =0.0001%)
Moreover they exhibit thermal hysteresis (R(T) cooling curve may be several ppm apart from heating R(T) curve) when cycling form 18°C to 28°C.
They usually fulfill 0.01% specification, but to  get more from them  You would  need to keep them in constant temperature bath (probably in NCR they were used this way).
Offline Nanitamuscen
  • Country: ru
« Reply #9 on: June 26, 2023, 04:07:29 pm »
Resistance coils p331, p321, p310 are measured relative to standards of a class higher in oil thermostats. They can also be used without thermostating, but in a composition with a thermometer and a resistance table, taking into account the temperature coefficients that are indicated in the passport of each resistance coil.
A typical thermostat for these resistances can be seen in the attachments.
Offline Wallace Gasiewicz
« Reply #10 on: June 27, 2023, 07:29:21 pm »
TUMEMBER has a point, but using Texas as an example for his point is probably not the best example ( or, on second thought.  may it is). In the past, Texans frequently seemed to regard Texas as ALMOST another country, since at one time it was a country on it's own.
I think this frame of thought has changed recently with so many new residents in Texas.
I realize the history of Ukraine and the relationship with Rus is different and far older than history of Texas with the rest of the US.However I know just enough about Eastern European History to know that I do not really know anything.
« Last Edit: June 27, 2023, 08:46:39 pm by Wallace Gasiewicz »
Offline EC8010
« Reply #11 on: July 16, 2023, 04:02:32 pm »
This morning, I bought six very similar resistors (0.1, 1, 10, 100, 1k, 10k) made by Cambridge Instruments (UK) at an amateur radio rally for £85 the lot. I've just tested them (fortuitously, the lab was at 20C) and they agreed sufficiently closely with my 34470A 7 digit DMM that I probably believe the enormous resistors' calibration values (1987!) rather than the meter - which must have much smaller resistors. I told my wife that these resistors normally live in a temperature-controlled oil bath, "I hope you're not going to do that here." I think that means an oil bath has been vetoed for the moment.
Offline alm
« Reply #12 on: July 16, 2023, 04:19:51 pm »
if the look very similar, then they may well be USSR-made that were rebadged by Cambridge Instruments. I have a R4030 resistance standard that was made in the USSR but branded "Time Electronics".
Offline EC8010
« Reply #13 on: July 16, 2023, 06:02:28 pm »
What I really meant was that they were large and cylindrical. Mine are about the size of a 500g treacle tin (and oil-filled). But they have enormous solid copper cow horn handle bars coming out the top with a pair of screw terminals at the ends to make the four wire connection.
Offline alm
« Reply #14 on: July 16, 2023, 07:13:13 pm »
Try looking for information about Leeds & Northrup 40xx series resistor, or Rosa / NBS type resistors. These likely are fairly similar. I would suggesting opening a new topic in the metrology section if you have any questions about them, since they will have very little in common with the resistors that this topic is about.
