Author Topic: ADR1399 unobtanium ?  (Read 1155 times)
Offline deepfryedTopic starter
« on: July 17, 2023, 05:01:30 am »
I wanted to build a small voltage transfer standard using ADR1399 (more as a learning exercise) and since the eval board seems affordable I thought I'd buy one but it seems the reference and eval board are both unobtanium. Anyone know if this is still being actively distributed ?
Offline ycui@eml.cc
Online dietert1
  • Country: br
    • CADT Homepage
Re: ADR1399 unobtanium ?
« Reply #2 on: July 17, 2023, 05:58:25 am »
mouser.com show a stock of 234 ADR1399KEZ SMD references at € 21,22 each. It's not an evaluation board, but in my opinion that board isn't special anyway.
Regards, Dieter
Edit: They show an evaluation board image but it's the SMD part only. Why not use a LTZ1000? Boards/designs are "everywhere".
« Last Edit: July 17, 2023, 06:05:28 am by dietert1 »
« Reply #3 on: July 17, 2023, 06:46:12 am »
Thanks missed it, I'll wait a bit for the TO-46 package :)
Online Kleinstein
« Reply #4 on: July 17, 2023, 08:29:55 am »
The availabilty for the TO46 version was pushed a bit in the past. So I would not bet on the current estimated date.
The 2.5 weeks or so may still be worth waiting.  To a large part the older LM399 can be used as a drop in replacement for first tests if really needed.
« Reply #5 on: July 17, 2023, 08:52:32 am »
eeeks, I just ordered the TO-46 eval board. The customer support said they will have 7 in stock in August September. Fingers crossed.
« Last Edit: July 17, 2023, 09:37:41 am by deepfryed »
Online iMo
  • Country: pm
  • It's important to try new things..
« Reply #6 on: July 17, 2023, 10:01:00 am »
I wonder where all those TO-46 versions go.. Could it be somebody is hoarding them as a collectable wine?
 >:D
Offline r6502
« Reply #7 on: July 17, 2023, 11:23:41 am »
 >:D
Same to me, I asked ADI for samples about 2 month ago, but only LCC versions have been available at that time, so I got 5 LCC types ...
Science can amuse and fascinate us all, but it is engineering that changes the world - - Isaac Asimov
Online Kleinstein
« Reply #8 on: July 17, 2023, 12:32:49 pm »
The delivery date pushed out bit by bit does not look like someone buying them all, but more like a small problem with the production. The TO46 case is not that common and may well use old machines.
« Reply #9 on: July 17, 2023, 01:54:23 pm »
The last time I asked ADI for samples, they said nope piss off  :'(
« Reply #10 on: July 17, 2023, 01:56:53 pm »
The only reason I'm interested in the TO46 package is to use a socket, so if I stuff up the design I can reuse the reference without destroying it. Also, I've never used a LCC package and wasn't sure if it needed special handling during reflow / soldering.
