Author Topic: Passive Hydrogen Maser teardown!  (Read 4148 times)
Offline 5065AGuruTopic starter
« on: October 19, 2021, 06:18:42 pm »
Just added "update 5" to http://www.leapsecond.com/maser/
It gives details on "digging down" to the cavity of the Maser.
Lots of PIX!  :)
Cheers!
Corby
The following users thanked this post: SeanB, chickenHeadKnob, ManateeMafia, Echo88, Dr. Frank, edavid, chuckb, ch_scr, antintedo
Re: Passive Hydrogen Maser teardown!
« Reply #1 on: November 16, 2021, 02:08:53 am »
Just added "update 6" to http://www.leapsecond.com/maser/
It gives details on removing and opening  the cavity of the Maser.
Lots of PIX!  :)
Here is the "eye candy" shot of the storage bulb! :popcorn:
Cheers!
Corby
The following users thanked this post: Echo88, Vgkid, chuckb, ch_scr, Haenk
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #2 on: November 16, 2021, 09:10:39 pm »
Your interesting pictures reminded me of my last physics project. That was building an infrared optical frequency standard using a CO2 laser stabilized by a large OsO4 absorption cell, at 30 THz. The project was abandonded without completion after in 1989 the physics nobel prize went for the development of atomic traps.
Funds got redirected to trap research. Guess there are results by now.
Regards, Dieter
« Last Edit: November 16, 2021, 09:12:52 pm by dietert1 »
Online ch_scr
« Reply #3 on: November 17, 2021, 09:42:53 am »
That video had nice glory shots of the laboratory  :popcorn:
For a more in depth technical presentation, I can recommend this from the same researcher,
held at the BIPM conference regarding the redefinition of the SI constants (26th CGPM)
The following users thanked this post: Vgkid, richnormand, dietert1
Re: Passive Hydrogen Maser teardown! (update 7)
« Reply #4 on: February 03, 2023, 11:19:55 pm »
Find update 7 here:
http://www.leapsecond.com/maser/UPDATE7.pdf
Cheers,
Corby
The following users thanked this post: chuckb, ch_scr, notfaded1
Offline notfaded1
« Reply #5 on: July 21, 2023, 12:33:48 pm »
Sweet Corby... I missed this!  It's been busy at work.  Any recent updates?
Bill
.ılılı..ılılı.
notfaded1
Offline rubidium
« Reply #6 on: July 21, 2023, 06:04:41 pm »
Rather amazing work! You gotta have real stones to take on an effort like this!  :box:
« Reply #7 on: July 21, 2023, 06:28:55 pm »
After some work, including adding an oven to the vacuum chamber, I was able to take some measurements.
Unfortunately For some reason I cannot get the cavity to tune properly at vacuum and at the correct temperature. Seems like the loaded cavity arrangement is very sensitive to changes. I did evaluate several new varactors and could get a proper range of tuning but the center frequency could not be obtained! :)
Put the project to the side for a bit to regroup.
Cheers,
Corby
